EAC fail
2005 1.4tdci JU
On way to work yesterday - lost the will to accelerate, eac fail appeared.
Pulled over turned everything off, removing key - waited for a few min restarted and continued 20 miles to work without any issues.
leaving work, it re-occured 3 or 4 times but limped home.
See plenty of info online regarding throttle body, wiring, connectors,  pedal etc to look at and diagnose.
However i noticed last week alternator is also on way out (after monitoring voltage) - is it possible alternator voltage fluctuation can cause eac to appear ?
Note, probably a coincidence... i had cam belt + idler etc, and aux belt replaced last month.
  • 1 month later...
Update on this one, EAC fail appearing was due to alternator control cables being rotten and corroded - battery voltage 11.4v, replaced the 3 pin connector and rewired got rid of the message with alternator now running at 14.5v,  however car still in limp mode which was the MAF sensor at fault.
No fault codes appeared on the obd scanner, but it is an old one which is due to be replaced with a better / modern one.
Trev, I do like the way that you post solutions to any of your problems
  • 3 years later...
You seem very knowledgeable about Fusions I have a 1.4 tdci 2004 trying to find a MAP sensor looked everywhere also my mate who is a mechanic cannot find it in the obvious places any clues please? Thanks Roy
It's on the back of the airbox, left hand corner.  There's a tiny rubber pipe from the MAP across to the boost piping.  It is a bit on an odd setup.
Tom we've been there with photos ect we've had the whole air system to bits no MAF
Sorry MAP
2 hours ago, Roy Kendrick said:
Tom we've been there with photos ect we've had the whole air system to bits no MAP.
If it was built pre-2004 to Euro 3 emissions standards then it won't have both.  Just a MAF.  The MAP was added from Jan 2004 onwards for Euro 4 emissions.
