Changing gear
Hi all
I have a Ford Mondeo 2015 when I start the engine and go and put it in gear it is really stiff sometimes impossible. But when the engine is off and I put it in gear it's no problem. When I start the car it always comes up saying press the clutch even though the clutch is engaged.
I've looked on the other sites and seen it's could be a possible of 1 of 2 things.
1. Clutch master cylinder
2. Slave cylinder
Has anyone else had this problem. Roughly how much do you think this would cost.
Ross
Hi Ross, it could also be the clutch itself that is causing it to not fully disengage, usually a failed/failing clutch cover but obviously a complete clutch should always be fitted.
If its the slave or master the pedal should feel soft/spongy and not firm as soon as you touch the pedal
naturally it is much cheaper to get the slave and master checked out first
Hi, as a workaround, try putting it into 2nd gear first, then from 2nd, put it into 1st. (works with a worn syncromesh)
