DTC 01 C41568
What dose the fault code Dtc01 C41568 mean
I take it you've got this from the instrument cluster rather than a plug in obd2 scanner? If so the dashboard method is pretty useless and don't mean much, you can ignore it.
If you're having problems then plug in using Forscan and read the codes properly.
