Ford Mondeo rear boot badge
Hello, Don't be fooled into fitting the wrong replacement badge on the Mondeo boot. I bought one recently and found it did not fit. You need to buy the Fiesta badge and be careful taking it off, if you use heat use a very low setting, otherwise the paint will lift. Also make sure the area is clean, otherwise the badge will not stick and fall off.
