Thermostat size
Hi first time posting. I have recently bought a 07 plate s max tdci 1.8 I had coolent loss so replaced expansion tank along with thermostat and housing the trouble i have is cant find the correct size thermostat for the car every shop i go to including ford give me ones that are to small i bought a kit off amazon with thermostat included but pipe from housing not getting hot and car overheating so want to swap with good make i have just had pump and belts swapped aswel I'm hoping someone else managed to find correct size thank you
What size have you got that is wrong and what is the size that you need ?
Sounds like you have the wrong thermostat housing fitted
Hi I need one about 35mm but everyone i buy is 32mm I thought could be the housing but I have had 2 now as I bought the second as a complete unit with thermostat after I could get the right size after buying just the housing and they the same might have to pop to car parts shop and measure there housing cheers.
