Side lights
Hi, my 2012 MK3 focus nsr and  nsf are not working after a bulb change and after putting a meter on the rear i had a reading of 7.6 Volt's, any ideas guys.
By any chance, did you 'upgrade' to LEDs? If so, re-insert them 180 degrees the other way...
EDIT: just realised you state the voltage is only 7.6v, it should be over 12v, not an LED issue then!
