Excessive wear on trailing arm bushes due to towing
My Smax has just failed the MOT due to worn rear trailing arm bushes. I have been towing a 1500 kg caravan this year. When I removed the bushes they just fell apart. Totally shot. Has anyone else experienced this.
you need to check the actual weight that is being applied on the tow hitch. It could be a hight problem between the caravan and car causing excess force on the cars rear suspension components.
Rear bushes are prone to wear on the Mondeo too same set up it's unlikely to be the caravan as your car is over 13 years old i the bushes have done well to last this long
