Looking to buy Ford Focus - need some advice
Hopefully you guys can me. I am looking at. 2009-2011 model.
Is the 1.6 underpowered?
Does the 6000cd work with Bluetooth music?
If the car is regularly serviced, does it matter if it has over 100k on clock?
Anything faults that I should look out for and stay clear of?
I have seen a 2011 1.6 Titanium, FSH, but 103,000 for £2695. Is that overpriced for a car in Kent? It only comes with one key.
Petrol? Diesel? Magic fairy dust?
No, phone calls only.
Not necessarily, but you'll have to do your own inspections for rust, rough running, look at the MOT history etc.
As cars get older some things can wear out like bushes, boots, suspension bits.  The rubber stuff.  I'd be interested to see if there are any bills for replacing these.  Engines can go a long time now if serviced but other stuff does wear out.
The 1.6 petrol is not major underpowered the focus is heavy so takes high revs to get up to speed which these engines can handle. They are not performance vehicles but are very reliable my last one only let me down by needing a new battery and I found it was the original. As above the usual bushes can go but parts are easy to get. Pay attention to the rear arches at the front of the wheel inner arch and the rear where the bumper attaches for rust. Also these engines make a tapping noise when cold but it goes when they warm up so don't let that worry you and they are very addictive cars to drive.
nt DURATEC 16V/MANUAL (09/2007 - 08/2011)
VIN WF0PXXWPDP8A22581
Interval 8 Years (100000 ml)
Repair/Order No
Reg. No.
Reg. Date
Radio Code
Mileage ml
Outstanding Field Service Actions. Please ensure they are completed.
No Campaign Message(s) found
L - Labour item - invoice at additional cost
Driving Vehicle into Workshop
Instrument gauges, warning control lights and horn Check operation
Clutch Check operation/adjust, if necessary (where applicable)
Windscreen, washers, wipers Check operation and condition, if necessary adjust/repair/renew (separate repair order required)
Inside Vehicle
Exterior and respective control lights; instrument cluster illumination Check operation/condition
Parking brake Check operation/adjust, if necessary (where applicable)
Seat belts, buckles and stalks Check operation/condition
Odour filter Renew
Outside Vehicle
Hood latch/safety catch & hinges + Check operation/grease
Under Hood
Wiring, pipes, hoses, oil and fuel feed lines Check for routing, damage, chafing and leaks
Engine, vacuum pump, heater and radiator Check for damage and leaks
Coolant Check anti-freeze concentration: 1pix.gif °C
Coolant expansion tank and washer reservoirs Check/top up fluid levels as necessary - in case of abnormal fluid loss, a separate order is required to investigate and rectify
Power steering fluid Check/top up fluid levels as necessary - in case of abnormal fluid loss, a separate order is required to investigate and rectify
Battery terminals Clean, if necessary/grease
Battery Visual check for leaks - in case of abnormal fluid loss, a separate order is required to investigate and rectify (LTS 31 214 4)
Valve clearances Check. If adjustment is necessary a separate order is required (LTS 21 213 5)
L
Under Vehicle
Engine Drain oil and renew oil filter (use torque 15 Nm)
Steering, suspension linkages, ball joints, sideshaft joints, gaiters Check for damage, wear, security and rubber deterioration
Engine, transmission, rear axle Check for damage and leaks
Pipes, hoses, wiring, oil and fuel feed lines, exhaust Check for routing, damage, chafing and leaks
Underbody + Check condition of PVC coating
Tires Check wear and condition, especially at tyre wall, note tread depth
RF 1pix.gif mm, LF 1pix.gif mm, LR 1pix.gif mm, RR 1pix.gif mm
Brake system + With wheels/drums off, check brake pads, discs, linings for wear and check brake cylinders and drums for condition; check rubber components for deterioration
Outside Vehicle
Engine Refill engine oil
Tires Adjust pressure
Instant mobility system Check best before date on tire sealant - if applicable
Spare wheel Adjust pressure, check wear - condition (note tread depth)
1pix.gif mm
Luggage compartment lamp + Check operation - if applicable
Wheel nuts Tighten to correct torque and check for correct type. Check for rim damage (use torque 90 Nm for Steel Wheels with gold coloured wheel nuts, 130 Nm for Steel Wheels without gold coloured wheel nuts, 110 Nm for Alloy Wheels with 2-Part locking wheel nuts and 130 Nm for Alloy Wheels without 2-Part locking wheel nuts)
Wheel covers Check for damages, especially at retainer system
Service record and reminder sticker Update vehicle service record (Service book/Digital Service Record (DSR) and affix sticker to driver side B pillar)
Service Activated Roadside Assistance
Ford Roadside Assistance Activate 'Ford Roadside Assistance' registration - if applicable (participating dealers only)
Extended Period Maintenance
Brake system Every 2 years - Renew brake fluid (LTS 12 154 4)
L
Air conditioning Every 3 years - Check temperature at the evaporator outlet tube. Check air conditioning lines for damage and leaks (LTS 34 619 1) (TSB 67/2002)
L
Cooling system Every 10 years - Drain, flush and refill with Super Plus(LTS 24 122 4)
L
Camshaft drive belt Every 100 000 miles/8 years - Renew (LTS 21 304 9)
L
Auxiliary drive belts Every 100 000 miles/8 years - Renew (LTS 21 567 5)
L
Visual body & paint check Every 12 or 24 months depending on vehicle type and build year/registration date. Carry out during operations marked (+) above - see detailed Check Sheet - if applicable (LTS 54 555 1 +)
L
Extra Services and Additional Offers * (optional - upon customer request / charged separately)
AC maintenance package Air Conditioning (A.C.) system check. Apply A.C. cleaner (recommended FINIS 2395156) to air distribution system. (LTS 54 552 4)
L
Odour filter plus Upgrade odour filter to odour filter plus
+ Visual body and paint check should be carried out during these operations on vehicles built from 03/2002 onwards - see detailed Check Sheet if applicable.
As long as the 'one' key is the master one, (with the remote buttons on the fob), you'll be fine. I got mine a couple of years back and it had a blade key, and a fob key, I always intended to get a spare fob, but the cost is prohibitive, even Timpson quoting me over £200.
Mine is considerably older at 2005, but the 1.6 engine is fine if you're not a boy racer, unfortunately, I am one at heart and it frustrates me every time I accelerate up a hill, and it goes no faster LOL It's very reliable if well looked after, mine has 110,000 on the clock, and is pretty rust free. The handling is one of these cars strong suits, I can corner round a roundabout keeping up with far younger & sportier cars!
If you do get one, the support on this forum is second to none should you need any maintenance advice.
Thank for all the replies guys. Some very detailed replies!
I have seen some cars described as belt driven and chain driven. Which is the best?
Also does the Sony stereo work with Bluetooth music as the 600CD doesn’t? Can the 6000CD be hacked to work with music?
I have attached a photo of the key fob.  Been told I can another official Ford key cut and programmed for £160.
It doesn't matter really matter. They should've all had at least 1 timing belt/chain change in its life. You still haven't told us what engine you're looking at getting.
No you can't play Bluetooth music on any mk2 focus using a factory radio. The Bluetooth is a separate module and they never made any new modules compatible with the mk2. To give some context, the iPhone 3g wasn't even released when the mk2 facelift came out. There was really no demand for music streaming, everyone was grateful for an aux cord in those times.
That's a keyless fob, which will be slightly more expensive I'd imagine. An auto-locksmith should be able to provide and programme the fob and emergency blade for you.
6 hours ago, Risco said:
... Been told I can another official Ford key cut and programmed for £160.
Now, make sure the bloke that told you that is the one that will charge you £160, and NOT the seller of the car LOL
Thanks, I am looking at a petrol engine. So 1.6 or 1.8?
Bigger is always better.  And if it doesn't feel right walk away.
It's not too bad TBH and not bad on fuel, a bit revvy at motorway speeds
A titanium will have a Sony unit and if fitted with bluetooth (look for voice button on top of remote) will stream bluetooth audio
6000CD - NO
No, but you will need to get the cambelt done ASAP if not done already
BCM (fusebox under glovebox) can get water contamination, disconnect some plugs and look for green fir on terminals,
Cluster faults are common but not so much on your age yet, cheap and easy to fix
Cheap fuel can damage front HEGO sensor and they are expensive, avoid if EML is on
You could easily get lower mileage for that money
Good Luck
