Gearbox Breather
Had the clutch changed on my MK2 focus 1.6 with new gearbox oil 18 months ago. A few months back I noticed a fair bit of oil under the car which I traced to coming from the end of the gearbox breather pipe which had split and was clipped at the back of the gearbox. I fitted a new breather pipe and clipped it under the battery box so it was higher up. Since then I've noticed occasional oil splatter on the plastic gear linkage cover (I've checked it's not the gear selector seal) so it can only be spitting from where the breather pipe pushes into the gearbox. It does have some oil around the pipe where it pushes into the gearbox but not much only residue. I've asked around and no one can explain why oil would spit from there? It the gearbox was overfilled it surely would have caused other issues by now?
