Mondeo just stopped.
Mondeo MK3 2.0 16V 2005 146Hk
Stopped the car to unload stuff in the trunk, started 2 min later and drove 5 meters when it stopped and wont start again.
Cranks but wont start.
Im thinking fuelpump or ignition.
changed coilpack but same problem.
Anyone got any idéas?
Got the following codes.
Car Scanner ELM OBD2
DTC report
Selected brand: Ford
============1==============
P0015(93)
Raw code: 001593
ECU: Engine control unit[Archive (inactive)]
Status: Test failed since last DTC clear
OBDII: Camshaft position (CMP) actuator, exhaust/right/rear, bank 1 - timing over-retarded
============2==============
P0123
Raw code: 0123
Status: Pending
OBDII: Throttle position (TP) switch A/accelerator pedal position (APP) switch A - high input
Ford: TP Sensor A Circuit High Input
============3==============
P0301
Raw code: 0301
Status: Confirmed
OBDII: Cylinder 1 - misfire detected
Ford: Cylinder #1 Misfire Detected
============4==============
P1693
Raw code: 1693
Status: Confirmed
OBDII: Turbo Charge Control Circuit Malfunction
Ford: Turbo Charge Control Circuit Malfunction
If you've got a code reader, then clear all codes, and see which ones come back 'cos you don't know how old some of the codes are that you've read.
I did clear the codes but since the car won't start I don't get any new ones, except P1000 "Monitor checks not completed - More driving ReQuired"
So, it won't start, and you've got no codes.
Seeing as you've had no other replies - to be fair, the mk3 knowledge on this forum is a bit thin - try asking on the www.talkford.com forum, where there is a dedicated section for Mondeo mk3 petrol engines.
Thanks I will try that 😀
