Boiling by day cooling by night
Hello folks it's disasterfocus here again.After 8 months of incident free motoring the 1.0 coolant system has thrown a wobble.Noticed small leak from coolant bottle and replaced same and a new cap Filled up to max and went through bleeding procedure.Next day boy comes home with car and I check the coolant....Empty. Ambient outside temp 27.5 degrees.
Refill to max and take for a test drive up to temp.Return and check..coolant begins pishing out of the tank vent and I lose about 1 litre.
Check hoses...lower rad hose is cold.
Night falls ...ambient temp 18 Deg c refill and repeat bleed procedure.Same test drive...return ..not a drop lost.
Car was used again yesterday in daytime temp of 27 Deg c...same pishing out mullarkey from bottle vent
Esteemed members can I throw this conundrum out for your comments or should I just drive in the winter and at night ha ha..
