frost plug
i have a ford mondeo 2013 desiel was trying to change the frost plug just above the crankshat but it fell inside the block. Would that damage the engine at all???
i say yes nothing is suppose to be in the engine just floating around
It's an interesting question tbh.  I don't think it'll be light enough to float, even with the force of the waterpump.  So chances are it'll just sit at the bottom of the casting.  However, depending on the design of the water jacket, it could potentially restrict the coolant flow...
Which engine is it?
2013 FORD Mondeo Mk4 Hatchback 2.0 TDCi
Which engine is it?
Ah, not wet liners then, would be a pain to reach the plug even if you removed the head. :sad:
would you know if they are brass or steel originally???
Steel.
