Help with Bose Headphones model........Any help would be great.
I have just had some Bose headphones,all thats on them is Bose Techniks Pro Bass,added 2 pics below.any help at all will will be great.
Are you sure they are genuine? I’ve never seen any like that over the years of buying their equipment. I take it you’ve googled the name and found nothing?
I aint got a clue if they are Genuine and aint got a clue how to find out,i have searched all over and they have radio on them and TF card slot.
They sound ok and all work.
Is there any way of finding out.
There should be a serial number or 4 digit could on them, inside the earpiece, on the underside of the headband, If they are wireless there will be one in the battery compartment.
Could email a pic to Bose.
I will have a look at that for the number,its a built in battery and do i remove the earpiece as unless i remove stuff i cant see any number.
I could e-mail them just will try and find the address.
Cheers.
These are 100% copy,i will put picture below but if these were £100 + headphones the plastic and earpiece would be way better than these.
You know you can just tell by feeling the plastic,as you can see below i have taken them apart and not a number anywhere.
They sound ok and work,not great or the best just ok,not a lot of bass there which made me think,they must mass produce stuff like this as i have worked on a plastic moulding machine they need to mould a good amout even to think of getting the machine running and trim and assemble them.
Cheers Mark.
