Changing the Digital Dash layout on the MK4 Focus ST.
I would like to know how to get the "Ford Performance" screen to work, I have been into the IPC Module with FORscan (is the APIM also involved in the change?) & tried everything I thought might work but no go, everything appeared to work like - ENABLING the Oil pressure display, oil temp display, etc, (same gauges as the 2nd image) then writing the new info to the module which all appeared to work fine but nothing changed, any help would be much appreciated, I have attached images of the standard Australian layout & the European/UK layouts for the 2021 Focus ST 2.3 Ltr SA series.
                       1st image - Australian layout below. (in sport mode)    2nd image - UK Layout (Normal mode with performance gauges (activated I think in settings under Display)      My Name  - John Humphreys.
  • 3 years later...
use the ucds
On 9/11/2024 at 1:50 PM, djcvss said:
use the ucds
Why ? 🤔
On 9/12/2024 at 11:53 PM, unofix said:
Why ? 🤔
I admire your optimism expecting an answer... 😂
Looking back through the thread I'm not clear what the OP meant by "Ford Performance" screen anyway. Only one I know is the "Ford Performance" splash gimmick when you toggle Sport mode.
  • 3 months later...
Iam almost sure this in the ipc not in asbuilt but the one with a dropdown menu is " myview perfromance screen "
I originally had it featured in clocks before amendingnthe asbuilt file but for some reason its gone , i probably changed about 10 items in the asbuilt file so it would have been that , what has caused the option to dissapear
  • 7 months later...
Got this on mine
