Aircon pipe
Hi, new owner here! I bought a 2008 1.8 petrol hatchback with broken aircon. Went underneath and found the final part of the aircon pipe is cracked in half. See attached photos. To remove it was a 10mm bolt head to the main unit at the bottom,  then a 13mm to detach it from the rear of the pipe.
Since removing I've bought the entire pipe System of a matching engine from the breakers but it doesn't have this final pipe. Also tried ebay but can't find any that have this little pipe! Can anyone guide me to what I need to order?!
https://imgshare.io/image/20210911-173928.pGSWVx
https://imgshare.io/image/20210911-170746.pGSmLj
https://imgshare.io/image/20210911-170756.pGSvll
Edited by Thomh1
Broken link
Adding additional piggott showing connections
Looks to me like FINIS no: 1742538
  • 1 month later...
Bought the part you suggested and jobs done! Thanks pal!
