Incode help
Hi I'm trying to program keys on 2011 mondeo can anyone here help with incode please
Are these brand new keys/fobs or ones that used to work for your car and just need reprogramming ?
These are new brand new keys, old keys were stolen with my other car.
The buttons for lock/unlock are easy to programme (will attach video).
The PATS transponder chip inside the key/keyfob is more difficult. You will need to download the software ForScan on to a windows laptop. To be able to programme keys you will need to buy the licence which is £10 for the year. You will need an ELM327 lead to connect the laptop to the OBDII port of your car. Once you are connected you will be able to delete the missing/stolen keys from the vehicles memory and also programme the PATS transponder chips of you new keys in to the vehicle.
ForScan:   https://forscan.org/download.html
ELM327 Lead:  https://tunnelrat-electronics.fwscart.com/USB_Modified_with_switch_ELM327/p4541936_17045457.aspx
Thanks. I have all the gear to do it but I'm after someone who can access ford etis to generate a incode for it. Have tried all other incode generators with no luck
You can register yourself as a private user for etis but I'm not sure how that will help. If you use ForScan then you just add the keys.
Also have you got keys with the right Transponder Chip, I think there are 2 possibilites for your model
I'll have a try tonight to register.  I have forscan but with my model car it needs incode to access key programming etc. Cheers
As I understand Forscan cannot program key past 2010 year ie. cannot do 4.5 models. it is dealer only
Hello @Kirky321, as far as I know the latest version of ForScan with the Licence will programme keys up to 2019
