Code po300
2008 ford focus 1.4 petrol hatchback
Cylinder 4
Is weak
Car cutting out
When I go to stop in traffic
Code po300
Edited by tophammer
How have you established cylinder 4 is weak? Eg compression test   Or    Listening to the effect of disconnecting each plug lead one at a time.   Or….    P0300 means misfire on more than one cylinder I believe. If it was only cylinder 4 I think the code would be p0304.
Exactly.
First point would be plugs and leads.
Then coil pack
Then compression test
Ahh TK for reply true what u said
Tryed everything
Even swapped
All coyle packplugs leads
From other 08 focus
Still hunting
Then  done compression test
4 slynder little bit weak cleared all faults with high spec computer
Drove on motorway
Not hunting as much
But when I slow down
Car cuts out
Apart from tht
Driving as new
Just fully serviced and
T belt and water pump
Last week
As u said it's cylinder 4
My mechanic
Says drive for the weekend
See how it goes
But he did say might
Be head gasket
Or the brain
Or valve
Any way I can sort this
Or will I have to replace
With 2 ND
Engine
What u think tk again for reply
P0300 Causes
(* = Most Common)
  • Faulty or worn spark plugs *
  • Faulty spark plug wires or coils *
  • Distributor failure *
  • Faulty fuel injector
  • Vacuum leak
  • Low fuel pressure
  • Camshaft sensor defective
  • Crankshaft sensor defective
  • Engine timing off
  • Leaking head gasket
  • Low engine compression
  • Poor quality fuel
Many thanks for your help
Car cutting out
When I go to stop or slow down
No reading on the crankshaft
Etc however done compression test
Cylinder 4 is week
Is it fair to say I could
Put spoon full of oil.down cylinder 4.was told to try slick 50.oil.car is driving fine other than.that like.engine light is staying of.so no fault s .as my friend cleared with.computer .iv done air test etc all is good.
Car cutting out
Cylinder 4 is week
The idea of putting oil into the cylinder is that if you do a compression test and one or more cylinders is lower than it should be then you put some oil in that cylinder and do another compression test right away. Do not start the engine though because the oil will burn off.
If the compression in the low cylinder then rises a lot to a near normal level then the problem will be with the piston rings/cylinder bores rather than the valves or cylinder head gasket.
I wouldn't waste my money on slick 50.
Your cutting out problem is unlikely to be anything to do with low compression unless they very low. As for what it could be then it is impossible to say from here.
What would you say problem is by car cutting out.just as I'm about to.stop just cuts out like
Idle What would you say problem is by car cutting out.just as I'm about to.stop just cuts out like.
U tube video
Idle speed control valve.replacment .might stop from cutting.out .
