tow bar
evening everybody is there anyone on that could code tow bar electrics for me it's on a 2010Mondeo estate titanium x sport or if you know someone thanks
Hello Scott, have you fitted the Ford Towing Module ?
On a 2010 Mondeo it's old enough that you still just 'Scotch Lock' in to the wiring without too many issues. You will still need an indicator slave/repeater unit but thats about it.
evening mate I used the plug and play no scotch locks used
So you fitted the Ford towing module 👍
Then all you need is a laptop with FORScan software and an ELM327 lead and you can programme it yourself.
Download FORScan from here: https://forscan.org/download.html
Buy the ELM327 lead from here: https://tunnelrat-electronics.fwscart.com/USB_Modified_with_switch_ELM327/p4541936_17045457.aspx
cheers mate will give a go and let you know and thanks for advice
