Please help!!!!!!!!! Ford Focus titanium X 2013
Please could someone help me!!! Ok my car keeps saying I have an ABS fault, it’s been to 6 garages including Ford  and they’ve all said said it’s something different, when plugged in the fault code is C0034-15 right front wheel speed sensor So far it’s had 3 new right hand sensors, a totally new wheel hub, all the wiring replaced and the last thing was a new ABS pump! Still the same problem! So I have no Speedo, no hill start assist and my dashboard looks like Blackpool illuminations. I would be so grateful of any help, thank you so much 😊
I wonder if anyone has thought to check the connectors on the BCM. This sounds like it could be the problem of water tracking through the loom from the washer pump which has been widely discussed on this forum.
I agree !!!
This sounds far more like a BCM problem.
Ok I will get this checked! Thank you! Xxxxxxx
Does anyone know any good Ford mechanics in the Derbyshire area? I’m reluctant to take it back to any of the people that have seen it so far as I’m not getting anywhere! Xxxxxxx
Hello Sarah, you really need a specialist auto-electrician, not a garage. The ideal sort of person you need is SY diagnostics but they operate in the Hull area, you could always drop him a message on his YouTube channel and see if he knows of anyone in your area.
Thank you very much indeed xxxxx
