How to use SatNav, radio etc. when engine is off
Mondeo Titanium 2015. When the engine off the car shuts down the ignition after 30 secs or so in order to save battery. How can this be overridden so that I can listen to the radio or use the SatNav without having to turn the engine on. Many thanks for possible solutions.
Does it not come on when you press the power button? Usually you get an hour when the engine/ignition is off. Unless it's different in a MK5.
If not then your battery may be low on charge and the car shuts off the unit to save power.
Hi. Thanks for your reply Frembrit. The power only comes on for a limited time when I press the power button without starting the engine. But as far as I am aware the battery is fully charged. Strange.
