sequential mirror lights
H all, I installed my new sequential mirror turn signal lights on my 2012 zetec diesel today, but for some reason they don't work when the engine is running. They function perfectly when the engine is not running, I have turned the connectors around but still no joy, they are suppose to be plug n play. Any help would be much appreciated Cheers
Do all the other indicators work ok? Have you tried clipping in one of the old ones to see if it works ok? Mines worked out of the box with no issues. If the original works ok with the engine on then I would return the new ones as faulty. Also found this review below so guess it's just a matter of luck on the quality. These are the ones I got and have worked fine for more than a year. https://www.amazon.co.uk/dp/B07Y3XVXVY/ref=cm_sw_r_awdo_navT_g_1EJ6V6Q5W8KWC8056BP8?psc=1
Yes everything else is working fine, I hooked the LEDs up to a 12v supply and they stay on full (no blinking) strange they don't work with the engine running. Thanks for your reply 👍
