Help with ForScan results for 1.8 TDCI please
Following on from my thread -
I have the following results I would like some help making sense of please:
===PCM DTC P1622-61===
Code: P1622 - Immobilizer ID Does Not Match
Additional Fault Symptom:
 - Signal is Above Maximum Threshold
Status:
 - DTC Present at Time of Request
 - Malfunction Indicator Lamp is Off for this DTC
Module: Powertrain Control Module
===END PCM DTC P1622-61===
===PCM DTC U0140-A1===
Code: U0140 - Lost Communication With BCM
Status:
 - Previously Set DTC - Not Present at Time of Request
 - Malfunction Indicator Lamp is On for this DTC
===END PCM DTC U0140-A1===
===OBDII DTC None===
Successful DTC reading, no error codes found
Module: On Board Diagnostic II
===END OBDII DTC None===
===ABS DTC None===
Module: Antilock braking system
===END ABS DTC None===
===EPS DTC None===
Module: Electronic-Controlled Power Steering
===END EPS DTC None===
===IC DTC B1318-20===
Code: B1318 - The battery voltage level is too low.
Status:
Module: Instrument Cluster
Diagnostic Trouble Code details
Possible causes are:
Battery voltage line - open or short
Poor battery condition
===END IC DTC B1318-20===
===IC DTC B2103-20===
Code: B2103 - No Signal detected at PATS module from transceiver. (Antenna not connected from transceiver)
Status:
PATS transceiver circuit fault.
--- Possible Causes --------
PATS antenna not connected
Transceiver resonds, but diagnostic byte says antenna defective
-Suspect Antenna or Antenna wiring Module
===END IC DTC B2103-20===
Start with the easy stuff first.
Charge the battery for a FULL 24 hours.
Normally I don't recommend clearing the DTC but I think in your case we have a full list now so after charging the battery clear all DTC and see what comes back.
Then it will be possible to see more clearly the cause of the problem.
Will do.
Just an update in the interim.
Tried to start this morning and for the first time it didn't start. Tested the battery and its goosed.
Bought a new one, put it in, and starts like a dream now.
Obviously, this doesn't solve anything as yet, as I will still clear the DTS as you mention, but just wanted to update
Your new battery should still be charged overnight so that it can be as near 100% as possible. Don't think just because its new it will be in tip top condition.
