Clutch pedal
So today whilst driving to work my clutch pedal got stuck down, after panicking and advice from my son I manually lifted the pedal with my hand, this worked great. Whilst awaiting I contacted RAC they checked car over and discovered low fluid and topped it up. My concern is he advised it may be a leak in gear box it may not it will probably happen again. I'm now very paranoid as pedal now squeaks. Any advice greatly received 2017 Focus STline 33000 on clock had 2 weeks......
Possibly the clutch slave cylinder seals are leaking. Just keep a careful watch over the clutch fluid level for the next week or two. If it starts going down then you need the system looked at.
It is unfortunate that for many years Ford have put the slave cylinder in the bell housing so the gearbox has to come out to get to it. In the old days you had a clutch cable or a hydraulic slave cylinder outside the bellhousing which connected to a lever sticking out of the bellhousing.   I don’t know if these concentric slave cylinders make the clutch nicer, eg lighter/smoother but they are annoying when they play up.
This is a known fault on the Mk3 Focus.  Master cylinder seals.  Shame you're out of manufacturer warranty but I'd still contact Ford to see if they'll offer any help or a 'goodwill gesture' due to the low mileage.
You say you've only had it for two weeks ?? If you bought it from a dealer/trader then I'm sure you automatically get 3 months warranty so, if it goes again, then they should be liable for the repair costs ??
