forscan
can anybody tell me why forscan won't connect to bcmii central configuration and need update for towbar electrics and parking sensors as they aren't working since fitting the towbar
What make / type of EML327 lead are you using ?
I got it from tunnelrat electronics ch340
Just to confirm that is the one with the manual switch on it? if it is......
Have you set up forscan in the setting to notify you when to flick the switch from hs-can to ms-can
If not make sure that the settings are correct in forscan for it
This might explain your problem:-
1 hour ago, JW1982 said:
Try to use an older Forscan version. The latest versions have a bug which causes an error while reading/writing the Central Car Configuration on the BCM and IPC.
I experienced the same problems while using the 2.4.4 Beta version and the 2.3.43 version (2.4.4 Beta has firmware update capabilities on top of the 2.3.43 functionality). After I reverted to the 2.4.3 Beta version the problem was solved.
Use the following links to download the older version:
https://forscan.org/download/FORScanSetup2.3.42.release.exe
cheers guys for the help but parking sensors still not working any ideas
What version of FORScan are you using ?
Do you get any sort of error when you try to turn on the towing module ?
