engine revs dying when it gets worm
Hi my 2015 2.0L tdci starts fine drives fine till it gets worm, then it won't rev, every time you want to press the accelerator the engine revs die and wont drive, and the amber spanner sign comes on the dash but sometimes it clears by it self, and you can drive away as normal but not often, I've connected to diagnostic, the fault codes say throttle housing, fuel pressure, and last one showed knock sensor, has anyone else had this problem pls, TIA
