front screen wash
hi guys,my front screen wash has stopped working, the rear one is fine,I've been told that it could be  the return valve on the pipe, any idea where it is,many thanks
Hello Andy, having rechecked your model, I don't think that there is a non-return valve fitted on the front screen wash. As you probably know the front and rear use the same pump it just runs in a different direction depending which screen needs washed. You are probably going to have to pull the pipe off the pump and front jets and then blow through it to clear any blockage.
This is the Ford parts for the front screen wash:
https://ford.7zap.com/en/car/99/code.6u,1.15405,2.36157,4.43740,6.38920,7.24135/0/2302/18287/80092/#2
and this is the rear wash:
https://ford.7zap.com/en/car/99/code.6u,1.15405,2.36157,4.43740,6.38920,7.24135/0/2302/18287/80091/
many thanks, I'll give it a blow and let you know
