Remap
🤪Thinking of remapping my 66 plate red fiesta from 140 to 160 bhp including extra components is this a problem!!
No problem for me, go for it.
Make sure it is a reputable remap place and you should be good to go 🙂
Dont forget to notify your insurance 😉
Probably worth mentioning that there are several threads on here (if you haven't spotted them already) concerning gearbox issues, even on a standard 140.
Example here:
https://www.fordownersclub.com/forums/topic/74395-synchro-ford-fiesta-10-ecoboost/
Example here:
I agree with above engine is fine. I am running 180 with a hybrid turbo and its been fine for over 20k now but I did change my gearbox out to the 6sp.
Running stage 2 and all fine,  I agree the gearbox does not like gear changes at 4500rpm 😂😂 other then that go for it
  • 5 months later...
Kenny_stline can you also remove the map ? Have you tried removing the map with your scc bluetune
  • 2 months later...
bit late to answer this, i moved the car on a bought a focus st, to your question yes the map can be removed and the original map can be put back on via the handset
