About brake light swich wiring diagram, 2008 ford s max diesel 2.0
hello?
My car is 2008 ford s max diesel Tdci 2.0
How can I get wiring diagram of brake light?
I've just replaced bulb of brake lamp but both brake lights do not work and a mechanic want to see wiring diagram of it to check problem in detail.
thank you
You need to use an 'Auto Electrician' not a mechanic.
What country and city are you in ?
Does the centre brake light work?  If not, I'd be checking the switch before anything else.
Seoul City/South Korea
Center Brake light(=boot) works, I will check brake light switch.
If the centre brake light (the one on the boot) works the the brake light switch is working. There is no need to test the switch.
