Many Problems Showing on Reader.
My engine light came on for a couple of days then went off again. I brought to a guy who read it for faults, this is the list that came up
C1306-A0, u0129-20, U1900-60, P1 402-60 (P0490-20) (P244A-20), P244A-20, P2196-26  Now I picked up the motor a 2010 Focus Estate 1.6TDCi and haven't heard from the mechanic since.  ( he was a friend's mechanic) so I'm bringing it to a proper garage to get sorted.  Is this an arm and a leg bill?  I got a mechanic to put a new EGR on it last year but one of the readings seems to show that might be blocked, also I'm in Spain and I doubt there is a DPF cleaner place if needed.  Any advice on what to expect is greatly appreciated, I can't really afford to replace it just yet.
Bump
Honest answer is there's not much we can advise with just a code list unfortunately.  That EGR code might even have been left over from before it was replaced.
One of them is for DPF pressure too low.  That suggests that maybe the pressure pipe has broken so that the pressure sensor can't take a reading.
You need to clear the codes and see what reappears when driving it. It’s a shame codes don’t come with a date as some can be old and not an active problem right now
Don’t rule out the possibility of the solder joint issue in the ip. Can throw up all sorts of errors especially u codes.
Thanks Guys, I thought it was definitely going to be a new DPF but hopefully not.  I'll update, it's booked in for next Wednesday.
