Drivers side door handle. Key hole cover replacement
I have a mk5 mondeo that has a key to start it. The drivers door handle has a removable cover over where you could use the key to unlock the door. I was at Tescos and when I returned to my car it was gone ( guessing an attempt to break in to it). Any ideas where I could get a replacement? And is it ok for the key hole to be exposed other than looking a bit crap?
Matt
It should be OK, but if you've got any lube, like silicon or WD40, then stick the straw in the keyhole and give it a squirt or 2, to protect the innards from the winter weather.
