1.8 TDCI "engine systems fault" message
Hi everyone, I'm hoping someone might be able to help me diagnose a problem with my car, I drive a 2007 1.8 tdci Focus which displays the message "engine systems fault" with a red light under heavy acceleration or heavy load (driving up hill usually) in 2nd or 3rd gear, which then disappears after a few minutes of normal driving. The usual "check engine light" is not illuminated and the car does not enter a limp mode nor seem to lose any noticeable power or performance while the "engine systems fault" is showing on the dash. I have plugged my obd scanner in which has given me the following two fault codes even though the MIL is not illuminated:
P010F-A2   mass or volume air flow sensor A/B correlation
P0380-68   glow plug control (GPC) circuit
If anyone has any ideas I would really appreciate it, cheers in advance!
