Digital display
the digital display on my 2019 zetec focus is just in two shades of white  even the ice weather warning doesn't go amber then red it stays white is this correct? My son has a 69 active focus and his weather warning is as it should be Amber then red ,auto brake is green and speed limit is red. So as I say is mine correct or is display faulty?
Yes it should be in colour so is faulty
Thanks for that ,so it should be exactly same as my sons
Should be the same as below unless somebody has changed the smd bulbs.
Mines the mk4
7 minutes ago, trolleyman said:
Mines the mk4
Do you mean the small icon on the top right hand side which is next to the outside temperature figure ?
If so. Then it should be in colour as suggested earlier.
Hope this helps.
Yes that's the one and should the auto brake icon and speed limit signs be in colour too ? Thanks for the help
FOC Admin: Is this thread running twice ?
8 hours ago, unofix said:
are saying the whole of your instrument cluster is just shades of white ?
Do you have actual gauges or do you have the simulated instrument cluster ?
16 minutes ago, trolleyman said:
Mines the mk4
Regardless it should have colours.
Sorry if it seems vague.  I mean the digital display that sits above the temp and fuel gauges and between the rev and speedo dials.
See video below, it's in German with English Sub-titles
