USB and Bluetooth not working n a 2009 Ford Fiesta
Guys , i have a 2009 Ford Fiesta with usb and bluetooth which does not work. When i press phone i see 'mute' on the display and in the settings bluetooth shows BT off. I cannot turn it on. Also the USB port does not charge or recognize the usb. Also Aux button is doing nothing. I have already removed and plugged again the bluetooth module but nothing happens. Any ideas to help me? Thanks.
Has it ever worked in the time you have owned the car ?
Sounds to me like your system does not have Bluetooth, even if someone has added the module it would still have to be activated in the software
  • 1 year later...
Hi Chris
I bought same car and have the same problem!!
have you solve the problem??
Chris is whats known as a 'One Post Wonder' so don't expect a reply.
If you have the exact same problem, then the exact same answer will apply.
