Car wont start up
Brought a s max less than a month ago and drives lovely when it starts, but most morning u go to start it up and its like luminations on dashboard
The latter could be litterally anything...
Ive ordered a ecu so hopefully that will fix it thanks
That sounds drastic at this stage. Did you really mean ecu?  Using a fault code reader might be a better first stage
hi,
there is a tiny wire going to the battery as with the time it oxides  and loose contact, computer will show all sort of errors like: engine malfunction, immobiliser malfunction, weak battery what you need to do just unscrew it, brush and clean put all together and problem should disappear.
Where abouts is the wire as ive changed ecu still doin the same thing so it might be this wire u told me about, but ive only just seen this sorry
I would say that you need to use a laptop with FORScan software and find out what actual problem is.
https://forscan.org/download.html
Its been on one it said the ecu and its still the same, i drove it yesterday when he had put the ecu in and spark plugs, tgey today i try and start it up its like luminations on dashboard again and wont start
12 minutes ago, Kerry brauer said:
it said the ecu
That's a bit generic. A code reader will not say "its the ecu". You need the actual fault code.
Just said its the module, its been on 4 computers, just weird how when it works it works but they if standed like over night it dont
I begin to think there is some b0locks been talked here. So from your other post:
5 hours ago, Kerry brauer said:
Ive brought this s max 57 plate and since we have had it its not been starting up next day, i have replaced alot of things like glow plugs, battery, ecu, sensor and so on could some plz tell me wot it can be as im am sick of wasting my money. Its been on so many different computers thanks kerry
and from this post:
So you have replaced the "glow plugs" and also the "spark plugs" what kind of fuel does your engine run on ???
What u mean? I just want to no if anyone has had the same situation. The car drives good when i can get it to start. So i just don’t understand wot it can be thanks kerrt
Petrol - Diesel - LPG ?
Deisel
I think you need to use a new garage and also ask for a refund on the new spark plugs.
Afraid you have to take it to the ford main dealer to get it properly diagnosed, they will have the correct equipment & software diagnostic to do the job, other garages will use something generic which may work well on some cars and not so well on others.
