Throttle Body ?
Hi all
Wondering if anyone knew where i could get (if they even do one ) a larger throttle body for the Zetec S 1.6 petrol ?
Had a 65mm one for my focus and acceleration improved alot !. Basicly it's a larger diameter which opens sooner
Yeah people do the 60mm Mondeo throttle body when they bolt on the cosworth inlet manifold to their ST's! Apparently massive difference in performance!
Hi all
Yeah, check out european-parts.net, they have one if you want to splash out a couple of hundred pounds.
are they easy to fit? like and would u need a re-map to gain any real performance increase from it?
If i can find one and it's anything like the focus one they are fairly easy to fit, and the ECU's do "learn" so they do adjust themselfs to the extra air and throttle response
Just need to find somewhere that makes or sells them :unsure:
there dont seem to be much out for the fiesta in way of big performance change as of yet i think but if you look at older models there is everything, so fingers crossed after time stuff will come out
