my fiesta doesn't start
Hi you all,
I'm Anna from Italy, I'm a ford fiesta's 1.4 tdci owner.
My fiesta was made in 2010.
Since november 2021 and still now, my fiesta has got a problem when starting, the car doesn't start.
This happens only in the afternoon when i have to come back home from work.
This never happens in the morning even if it is very cold.
I have already replaced the bactery, the glow plugs, the diesel filter, my mechanic has also tried to tighten the
diesel pipes near the filter.
No solution, all these repairs had failed.
Can someone help me?
Hello, you need Forscan to read codes so that you know what is wrong. It could be anything
no errors in diagnosis
try cleaning all the earthing points on the cars body 🙂
what did you use to read the DTC's ?
Hand held generic code readers do not normally read Ford specific DTC's. As already said you need to use FORScan, it will be able to read the Ford codes and also give reasons.
i took the car in ford. They had no answer to the problem
There MUST be as the MIL is staying on when the engine starts, what are you using to read codes?
I used Ford Scan. Nothibg in diagnosis
how did you connect it ?
my mechanic in ford connected the ford scan
Then you need to find a real auto-electrician who knows how to use "FORScan"
https://forscan.org/download.html
It is impossible to have an EML on and there be no DTC.
When using forscan,u will also need a n interface capable of both high speed and medium speed can
