Help On My Brakes
Hello can some1 help me i just bought a fiesta s with no brakes the guy i had it off told me he put a new abs pump on there so i took it home bled the brakes and coming to the front drivers side no fluid at all so i took it of the abs pump and blown down the brake line and it was not blocked the brake pedal goes to the floor when i put it all back together still the same help plz
have you tried pressure or vacuum bleeding?
yer mate i used a easy bleed kit so what i done i took off 1 brake line off the master cylinder it !Removed! out so i put that 1 back on and done the same on the next 1 and nothing come out so im thinking is it 2 do with the master cylinder??? cheers let me no what you think cheers
