Power wing mirror and indicator repair
Hey,
I own a 2013 FORD FIESTA LX WT 1.6L HATCHBACK, and recently my passenger side power wing mirror could not work, as well as the indicator on it. I want to repair it by myself and have done some research on this but unfortunately I have not found the solution yet. So I am seeking help from the group and see if anyone is on the same boat with me?
Also, does anyone know what size of low beam headlight bulb is on my car, some websites say it is H7 and some say it is not. I am bit confused.
If you remove a mirror, before you pull the cables out tie a length of string to the end so that you can use it to pull cables back again.   Otherwise it the very dickens of a job to thread the cables through.
