Mk7 1.4 TDCi high miles steering issues
Does anyone know what would cause 'clonking' when turning the steering wheel  and also a 'ticking' noise when driving and veering left? I've replaced the track rod end ball joints and it's helped the ticking sound a bit but still there, is it even safe to drive like that??
Sounds like a driveshaft on the way out.
I don’t know where your clonking is from but mk7 is known to have a problem with clicking from universal joint on the steering shaft up under the dash. Due to needing oil /grease. I’ve not had the problem myself but read about it loads of times on this forum
Yikes is that a big/expensive job?
Is yours a high miler though Isetta? Mines done a giddy 137k 🥴😵
Almost certainly the n/s CV joint.
The cv joint part itself is not too expensive, if getting a garage to sort it the labour will push the price right up. Its not a 5 min job. Last time I did one myself was 2 decades ago, and that was on the street. Garage hydraulic ramps make the job easier. 🙄
Ok many thanks I'll go get it priced up 👍
