Silly Question ?
Trying to avoid a load of soldering. Has anyone seen or heard of a double W5W socket, Tidying up the wiring in the boot and want to have 2 feed sockets coming off the interior boot light wires. Some kind of splitter thing.
Any ideas please, put in general as it didn't really fit anywhere else.
W5W is a lamp holder, isn't it ?
Can you post a picture of what it is you are doing, then I might be able to give you some ideas?
the boot light socket takes a w5w bulb flat blade type thing. I want to run 2 x 48 LED flat plates and mount them under the parcel shelf supports one on each side as they will be tucked up out of the way of getting covered or banged. I want it bright when rooting for tools or putting my fishing tackle away etc
I just used a couple of spade connectors and plugged the directly in to the plug on the loom.
I've successfully used Skotchlocks for things like this in the past.
I'd forgot all about skotchloks, cheers
