2009 MK7 Fiesta hearing a noise only when turning right and high speeds.
I have a 2009 Mk7 Fiesta and have had this problem since around January time I think, there a slight kind of bumping or knocking only when turning right and at a slight angle, not as noticeable at bigger angles and the steering wheel also begins shaking once you get to around 70mph. Had hit a relatively large pothole (on the front left side) just before I first heard the noise so check the wheels first and front left was buckled so I got it straightened out however this didn't fix the issue, just fed up with it now had a look around back left, everything seems tight, nothing obvious. Looking for any help or advice on the problem and am happy to reply to any questions you might have.  Thanks for the help in advance!
