Air Con
What's the best way to check if your a/c  is working 100%. I've just had mine regased, but it does not seem to be putting out  really cold air.
Have you got a thermometer you could stick in the vents?
There's no real set temperature because it depends on the temp of the incoming air...but there should be a noticeable decrease compared to that.  For a very rough idea I'd be expecting around 5c or so at the vents.  It should also feel 'icy' to the touch, as when opening a fridge door.
remember to turn on the air recirculation button so it not drawing in and fighting more hot air
I'm assuming you never got it done at KwikFit? They measure temp before & after, and after regas,  if not reached to a predetermined level, you get a refund...
