Ford Fiesta problem
So recently my Ford Fiesta electrics have started playing up my reverse sensors are not working ,rear wiper isn’t working ,screen wash front and rear isn’t working also also when unlocking the car the boot also opens is this a problem anyone has had before? If so any ideas on how to fix it thanks ?
Hmmm - this sounds like a pretty unusual set of circumstance but I'd be wondering if anything on the canbus is causing an issue with comms between certain modules, this would be one for Forscan and the correct OBD lead, OBDLink EX usb (my fave and recommended by Forscan.org)
My best guess, is an issue with the BCM (Body Control Module) - maybe a battery disconnection (reset) would kick it back into life, worth a shot for free.
Otherwise, it's all guesswork and that costs time, money or both in the long run.
See if someone near you has FS and knows how to use it, or buy it yourself (software is free, OBD cable costs a few quid) then get a laptop on the car and see what's what. Depends on how computer & car savvy you are of course. There you will find the fault messages and be able to test stuff directly.
You could at least perform a master reset on each module, to see if that cures it, using Forscan
