ford fiesta st-line 2019 mark 8 power point cigar lighter fuse
2 minutes ago, Eugene82 said:
stops work after freezing, it means it is damaged?
Quite possibly. You need to remove it and test it.
Thanks, Is it same pump for rear and front? I hear the sound (with no water) when I try to spray rear
It could be that the non-return valve for the rear has failed. It is not unheard of and is easily fixed by replacing it or removing it altogether. It is in the fluid line about 6 inches (15cm!) behind the nozzle.
Do you know OEM part number?
There is just the one screenwash pump. It rotates clockwise when pumping water to the front screen, and it rotates anti-clockwise when pumping water to the rear screen.
So, if I hear noise when I try to pumping rear and dont hear when from, where is the problem? BTW does it feat? https://www.autodoc.co.uk/meyle/10158019?search=MEYLE Water Pump, window cleaning (714 016 0000)
Do you get any water at the rear window ?
If the pump does not run when pressing the switch for the front, it could be that you have a faulty wiper/washer switch stalk.
Water doesnt run from the rear but there is noise from the pump, front totally quiet
I would say you have a broken pump.
  • 9 months later...
On 5/31/2022 at 10:03 AM, unofix said:
Thank you for the photo. That is in fact the fusebox in my original post, and the fuse for the cigar/aux power socket is number 83.
See the fuse in the RED circle below:
Hi there,
I have this same fuse box and am looking for the driver's side tail light. Can't see this labelled in the manual. Any help please?
There are no fuses for any of the lights except the High Beam. The parking lights/ sidelights are monitored and electronically protected by the Body Control Module (BCM).
