Hello
Hello
I've joined the forum because my daughter has a problem with her fiesta.
I know it's a cheek but the car has broken down twice now. No warning just stops.
Red warning service now.
Here's the AA report.
Doesn't look like anything there to critical to cause a breakdown.
I would appreciate anyone's thoughts.
Patrol found the following fault code/s:System : Engine control 1 - ZA4 / Motronic MED 17.0.1P080702 - Clutch pedal position sensor. Error Message : Signal error.P086B1E - Neutral position sensor. Error Message : Outside specified range.P08AE00 - Neutral position sensor B. Error Message : Outside specified range.P086D00 - Neutral position sensor. Error Message : Signal too high.P08B000 - Neutral position sensor B. Error Message : Signal too high.P086B - Neutral position sensor. Error Message : Malfunction.P08AE - Neutral position sensor B. Error Message : Malfunction.P06A701 - Sensor reference voltage B. Error Message : Outside specified range.P06A013 - Variable air conditioner compressor. Error Message : Open circuit.P086A00 - Neutral position sensor. Error Message : Open circuit.P083200 - Clutch pedal switch 1. Error Message : Signal too high.P083500 - Clutch pedal switch 2. Error Message : Signal too high.P06A100 - Variable air conditioner compressor. Error Message : Short to ground.P019317 - Fuel rail pressure sensor. Error Message : Interruption/signal too high.Tap fuel rail pressure sensor, clear codes and follow
The service we provide is essentially an emergency breakdown assistance service and is not equivalent to the service carried out by mechanics working in a fully equipped garage or workshop. Please note in particular that we can only test for and discover so much in a breakdown situation.
Make sure that you get any symptoms we have identified or possible faults we have suggested checked out by your chosen repairer before getting any further work done.
Matt
Hi welcome
This section is really for introductions, you're best posting the question in the specific model forum for the most views.
The fault most likely to cause a cut-out is the fuel pressure sensor one.
