Sony stereo Bluetooth
Help! Recently bought my son a fiesta titanium, when I try to connect phone it says too many Bluetooth devices connected and to debond current devices, when I press debond it checks for devices but doesn't find any, has anyone came across this? Is there a fix or a way to reset the Sony stereo unit? It's a 61 plate. TIA
can you hard reset it ?
I've no idea how, tried disconnecting battery for an hour but no joy
You probably have a faulty bluetooth module which is fairly common.
If you totally remove the glovebox and look up inside you will most probably see the BT module held in place on a metal bracket. They can be awkward to get off the bracket but just unplug from the wiring.
Look on eBay for a used replacement, expect to pay between £15 and £30
if you put make and model into google it will possibly tell you, either disconecting or pushing 2 buttons at the same time.
