P0130
Hello everyone,
i have a fiesta 2006 1.6 petrol and recently got check engine on my dash. Scanned the error with a badic obd scanner and it looks like the O2 sensor 1 bank 1. Cleared the error but it still shows in pending.
Can someone tell me the part code for that sensor? Should I replace both sensors pre and post cat?
I live in Hatfield postcode AL10. If there is someone who can help me i would appreciate it.
Car has 65k miles.
Thank you!
The part number for the pre-cat sensor should be 1143514.  You may not want to buy a genuine one though, as even with the 20% discount, they're not exactly cheap!
Genuine Ford Fiesta MK6 Fusion Lambda O2 Oxygen Sensor 1143514 | eBay
I wouldn't replace both sensors personally.
6 hours ago, TomsFocus said:
Thanks for your answer! I appreciate it!
 Bear in mind it might not be a sensor fault.  It probably is , but it could be a damaged wire or dodgy connector plug. So you should at least do some checking of the wires / connector before you buy a sensor.  People say they can be very hard to undo.  I have only done two and had no problems but I have often heard people say they can be troublesome to undo
I recently bought a NGK one for a corsa for about 30-40 quid I think.   There are cheaper Chinese ones on eBay but whether or not they work or for how long is a bit unknown.
Thank you for your reply! I will inspect the wires and try to give it a good clean to the connector as well!
Just checked the wires, everything looks ok. Unplugged and plugged back a couple of times. Error is in pending at the moment. Just ordered a new sensor and a tool to change it.
