MK2 Ford S-Max outer tail light cluster - can it be opened?
Hi everyone,
One of the LED strips from the right outer tail light cluster on my 2015 S-Max (Titanium) has stopped working.
I took out the cluster (pretty easy), but it looks like it's glued shut.
Has anyone managed to open / fix this? Or is it time for me to set an alarm on eBay / check breakeryard?
Also, the part number I have on mine is EM2B-13404-BG, but on eBay I found one ending in -BP. Is there a difference between them?
Thank you,
R
The plastic is Ultrasonically welded. Once sealed it would have to be cut open with something like a Dremel.
  • 3 weeks later...
I have the same problem. So, is there a difference between them?
Thank you!
Regards from Slovenia
So the answer will be the same.
I don't know
