MK 6 electric window
Hi all.
I have a 2008 facelift MK6 and the passenger side window wont go up.  It went down on the button and just stopped working.  I have swapped switches with a known good one, checked the wiring as much as I can and cant see any problems.  HELP
sounds like the motor has pack up ☹️
You're going to have to take the door card off and get to the wiring plug on the motor. Use a multimeter and see if you get voltage at the connectors when you press the switches.
