Ford Fiesta Coolant Tank Cap Replacement Different Model Number and Shape
Hello. I'm trying to figure out if I can swap my old coolant cap with a newer version that is a different shape underneath. The kpa and psi are the same.
Can I swap 3m5h 8100 ad for Dg9z 8100 a?
My car came with this model number: 3m5h 8100 ad (on the left in the picture). The replacement cap is Dg9z 8100 a but looks different. Does it matter if the base shape doesn't look the same as the original one?
Thanks if you can help.
It should be totally fine. It is just a newer design as the original type often fall apart.
